Zenith Carburetor
Cannonbal
08-28-2006 07:16:48
I have a Farmall C that may need a new carb. It must have broken at some point because previous owner had some welding done on it, and the flange isn't true, anymore-- warped a little. Carter is the carb manufacturer.
I see where I can purchase a Zenith carb which is supposed to "outperform" original equipment. Does anyone have experience with the Zenith carb? I'm interested in performance and compatibility with existing linkage, air inlet location, etc.
Any comments? Thank you.
gab
08-28-2006 17:52:21
 Re: Zenith Carburetor in reply to Cannonbal, 08-28-2006 07:16:48
I replaced a Carter with a new Zenith on my Super C. It"s worked good, no more fouled plugs or drips on the floor. Jim
Cannonball
08-29-2006 05:50:39
 Re: Zenith Carburetor in reply to gab, 08-28-2006 17:52:21
Did the linkage match up, and was gas inlet and air inlet compatible with the Carter?
Thanks for your reply.
RustyFarmall
08-28-2006 08:10:58
No experience with the aftermarket Zeniths, but I have rebuilt, or I should say attempted to rebuild, a couple of those Carters, and I honestly don't know how those Carters lasted and performed as long as they did. The Zenith has got to be a better carburetor.
