12 volt conversin starter
JayWalt
08-28-2006 20:45:01
why dont these kits include starters? Do they just run 12v into the starter, and if so, isnt this hard on them, or are they dual rated?
John T
08-29-2006 06:21:33
 Re: 12 volt conversin starter in reply to JayWalt, 08-28-2006 20:45:01
Jay, When I convert I keep the old 6 volt starters and they work fine. Due to the extra kick in torque it could possibly be a lil tougher on starter drives but Ive never really had a problem, I try to avoid long crank periods. It can help on the 6 volt systems to use 00 Gauge battery n starter n ground cables and a good high rated battery.
John T
Bob M
08-29-2006 05:41:11
 Re: 12 volt conversion starter in reply to JayWalt, 08-28-2006 20:45:01
Conversion kits don't require different starters because they simply don't need 'em! 6 volt starters live long and healthy lives on a diet of 12 volts.
In fact when an engine is well-maintained an original 6 volt starter often see LESS wear and tear when operated on 12 volts. Some of my earliest conversions - now approaching 30 years of service - are still going strong on their original 6 volt starters
Hugh MacKay
08-29-2006 02:26:49
Jay: I'm betting you will have less problems with that starter on 12 volt, than a 6 volt system with the generator half working, too small cables and a less that fully charged battery.
One of the biggest killers of any starter is poor power supply, low voltage and amperage.
old
08-28-2006 21:07:46
Starters don't care if they run 6 volts or 12 volts. They just spin faster on 12 volts then they do on 6 volts. I have used 6 volt starters for year on 12 volts and as long as you don't spin them to long they will last a long time
P Backus
08-28-2006 21:07:05
The normal practice is to just use the 6 volt starter. They work fine and they only run for just a few seconds usually. I"ve never heard about someone burning one out or otherwise having trouble.
Paul
Patrick Martin
08-28-2006 21:39:59
 Re: 12 volt conversin starter in reply to P Backus, 08-28-2006 21:07:05
What the guys above said is right on but you might want to put fresh brushes and bearings/bushings in the 6V starter while you have it off if your working on it. I just yanked my old starter off and found that they were quite worn.
