original paint color
Johnny Gray
08-29-2006 11:45:09
does anyone know if the original farmall red paint has a standard paint #? For example RAL-7012 is a standard number for a machine gray. It would be handy to have a number like that for the original red farmall used.
thanks
CNKS
08-29-2006 17:24:55
 Re: original paint color in reply to Johnny Gray, 08-29-2006 11:45:09
IH 50, 1936-1949; IH 1102b (maybe a) 1949-1958; IH 201 1958-1961; IH 2150, 1961 --until they changed it, I don't remember the next number. All of these are called "Harvester Red" 50 was changed to 1102b in mid 1949, I believe, did not coincide with a model change. 201 began with the 460/560, etc; 2150 began with the 404/504. IH 50 crosses to DuPont 7410/PPG 70019, 2150 crosses to DuPont 96766/PPG 71310, both cross to Sherwin Williams/Martin Senour/NAPA, I do not know the numbers. 1102b and 201 may or may not be available, my PPG dealer says he can't mix them. Case-IH sells only premixed 2150 and whatever replaced it.
arod
08-29-2006 16:21:34
Case IH sells international harvester red at the dealership.
remember, mass production rolls things out as cheap as they can, you are better off applying your own standards and picking a NAPA crossfire automotive paint that strikes your fancy, add an extra shot or 2 of hardener and you will be very proud of your BETTER than factory tractor.
aaron
