IH B2275 Help
Jan Larsson
08-29-2006 15:00:52
Sorry,my english is not the best, i`m from sweden.
I`ve been renovating the motor on my tractor and i need to know what the "momentum" is on the bolts that holds the top of the motor down and if i should "do them" in any special order.
I`m thankful for any tips and help unles i`ts my grammer.
Thomas the Terrier
07-02-2007 08:51:25
 Re: IH B2275 Help in reply to Jan Larsson, 08-29-2006 15:00:52
Hi Jan, i'm also from Sweden and have recently bought a B2275. I can't email you but if you see this, please respond.
I have a picture posted on the webaddress below.
The swede
08-30-2006 09:24:27
Thanks all
Now i know what i will do this comming weekend.
Tightning bolts and listen to old ABBA records.
And hopefully get the beast started.
I`ll be back (the tractor is old and bad)
El Toro
08-29-2006 16:37:53
Your English is very good and the bolt torque that you are requesting isn't in any of my manuals. This appears to be a British made tractor. Someone else may have the torque specs
for the cylinder head. You need to start in the center of the head and do a criss-crossing pattern
for tightening the head bolts. You need to tighten the bolts with a speed handle or a ratchet
until they are snug. Then use a calibrated torque
wrench to tighten the bolts in graduated increases until the max torque is reached. Use the criss-crossing pattern for this too.
You may want to send an email to sales@cefs.com
to see if they have the torque spec for the cylinder head. Hal
Jan Larsson
08-29-2006 23:52:47
 Re: IH B2275 Help in reply to El Toro, 08-29-2006 16:37:53
Just some extra information to my first message, the motor is the same as the one on the B-275.
i think its called BD144A. its a british made tractor and thats why i have so much problems with information and parts. Jan
El Toro
08-30-2006 06:29:11
 Re: IH B2275 Help in reply to Jan Larsson, 08-29-2006 23:52:47
What ever happened to the singing group ABBA? Hal
richard in nz
08-30-2006 23:46:58
 Re: IH B2275 Help in reply to El Toro, 08-30-2006 06:29:11
Just been a tv programe on tv here in New Zealand, seems they all got divorced and fell out with each other. They said they were Sweedens best export earner, second only to Volvo!
El Toro
08-31-2006 04:02:56
 Re: IH B2275 Help in reply to richard in nz, 08-30-2006 23:46:58
That group was very talented. Thanks for the update. Hal
The Swede
09-04-2006 14:10:38
 Re: IH B2275 Help in reply to El Toro, 08-31-2006 04:02:56
ABBA update part 2.
The 2 guys started writing musicals very successfully. i think they were the brain behind the group. The girls is doing a Greta Garbo, gone but not entirly forgotten. And finally the tractor runs like it never done befor.
Thanks
El Toro
09-04-2006 14:27:10
 Re: IH B2275 Help in reply to The Swede, 09-04-2006 14:10:38
Glad to hear your tractor is running ok. ABBA was well known here in the states and they had some good songs. Hal
PS: We have a lot of people in MN that came from the Scandinavian countries. I bought tractor parts from a man up there and his first name was Yalmer.
El Toro
08-30-2006 04:15:04
Here's the ft-lb conversion to newton meter. Hal
25 ft-lb=34nm
30 "- "=41nm
70 ft-lb=95nm
75 ft-lb=102nm
richard in nz
08-30-2006 01:22:06
You will have to convert this to metric if you need to as all my figures are English.
Head bolt Torque 70 to 75 ft/lbs.
Valve clearence 0.020 inch (engine hot) 11-----3-----6-----14 15----- ---9-----1-----8----- --16 ----- ----- -----2----- ----- ---- 13----- ----- ----- ----- ----- 12 ----- ----7----5----- 4----10-----
Above is the tightening order.
All manifold stud nuts are 25 to 30 ft/lbs
