Packings for old Farmalls
Loren in Iowa
08-29-2006 19:47:08
Would like to hear some tips from some of you guys, who have installed new packings in Farmall F20s, Regulars, and 10-20s or 15-30s. We put in new packings around belt pulleys, transmission input shafts, etc., but obviously did it wrong. They still leak. How about some helpful hints?
Kevin LA-CA
08-31-2006 20:25:16
 Re: Packings for old Farmalls in reply to Loren in Iowa, 08-29-2006 19:47:08
I used standard (rubber) lip seals in the PTO & belt pulley of my regular.
I measured the shaft diameter and of the ID of the threads. The local bearing place found appropriate sized seals. Then I slipped the seals in & squirted RTV silicone at outer diameter of the lip seal where it met the threads. I took a piece of pipe with the largest diameter that would fit and cut a length that would fit between the seal and the packing nut (with 3-4 threads engaged). This held the seal in place and not rotateing. Both have held for 10 years (limited use).
Shafts have to be 'reasonably' smooth and unworn where the lip seal rides. Could cement in a redi-sleeve if desired.
kevin
KEB
08-29-2006 21:16:32
1. Make sure the packing is the right size. It should just fit between the shaft & the housing. It has to expand enough to fill the gap between the shaft and housing when its compressed by the packing nut.
2. If there are multiple layers, make sure the ends in each layer are offset.
3. There's an art to tightening packing. It has to be tight enough to seal against the shaft, but not so tight as to overheat from friction.
If you are sure the packing is the right size, you might try tightening tha packing nut a little at a time & see if the leak stops.
Keith
