THANKS Andy Martin,Haas Kfox for the seal help on
Ted from Maine
08-30-2006 14:44:27
Thanks again guys, for all the help and info you gave me in changing my H tranny output seal,and the liftall pump input and output seals. I got them all in now. I goofed and didn,t put the lever inside the pump housing in the slotted bar on the pump and had to take the pump out and fix it. It's a long process when you use threaded rod to lower and raise the pump each time. Thanks again. Your assistance was most appreicated.
Haas
08-30-2006 19:31:36
 Re: THANKS Andy Martin,Haas Kfox for the seal hel in reply to Ted from Maine, 08-30-2006 14:44:27
Glad you got the job done. It's nice to get some feedback on occasion. You are not the only one around that has had to do a job more than once. Getting that lift all back together so everyting works is kind of tricky.
