H carb. jets
Minn Lou
08-30-2006 15:16:00
Can anybody tell me where the jets should be set on an H carb.Just rebuilt it and not,this H has an up draft carb.It is a 40 with the pony tank.I think it still has all orginal distillate mechanisms.Thank you for any tips
old
08-30-2006 15:56:38
 Re: H carb. jets in reply to Minn Lou, 08-30-2006 15:16:00
The idle jet the one up top of the carb is set about 1-1/2 turns out from bottom. The main jet I start at about 2 turns out but a lot of people say to have it around 5 turns out so I don't know for sure. The from there you have to adjust them till you have it running the way you want it to
CNKS
08-30-2006 17:25:31
 Re: H carb. jets in reply to old, 08-30-2006 15:56:38
5 turns out is the Super H setting. It can be turned in for better economy -- not adjusted like the H, which is in until rough, out until smooth plus 1/4 turn or so. Think of the Super series jet as a fixed jet like the C113 gas has, except that it can be leaned some.
