Farmall 140 Belly Blade
Capt Dan
08-30-2006 17:25:25
I am looking for original or after-market belly blade for Farmall 140. Where's a good place to look?
Hugh MacKay
08-31-2006 18:28:47
 Re: Farmall 140 Belly Blade in reply to Capt Dan, 08-30-2006 17:25:25
Dan: Those blades are not plentiful, compared to the numbers of tractors out there. That alone keeps them quite rare. I don't think anyone ever made an aftermarket blade that will bolt right up.
I see 5' and 6', 3 point hitch blades at TSC stores that could be very quickly modified to suit the situation you have. Basically all that blade had for mounting was a cross member between final drives, front side. Push beams from the blade pivoted from the cross member. For lifting all one needs is a lift rod up to the rock shaft.
