oil leak 154 loboy
stu in njo
08-31-2006 12:07:25
When mowing short grass no leak get into tall gras leaks out of rear main seal. Thanks for any help Stu
Nat 2
08-31-2006 12:33:15
 Re: oil leak 154 loboy in reply to stu in njo, 08-31-2006 12:07:25
I would say you probably need a new rear main seal, at the very least.
The leak may be more prevalent when the tractor is working harder because the engine is hotter, and heat causes things to expand.
Another possibility that I'm totally guessing at is that your main engine bearings may be a little loose, and the extra torque required to run the mower in tall grass is causing the crankshaft to shift off to one side a little bit. Just a total off-the-wall guess on that, though...
