Farmall H Head id
MartinD
08-31-2006 13:34:55
Just pulled the engine from an old ground power unit and installed it in my H.the head casting looks like 361 R1.Is this a regualr production head?
D Slater
08-31-2006 16:06:41
 Re: Farmall H Head id in reply to MartinD, 08-31-2006 13:34:55
Martin, Original H heads used 4 numbers followed by letter or letters suffix. If yours has a R1 suffix its a later head and should have 6 numbers before the R1. Sometimes part of numbers get ground off and you can see the ground marks. C 169 and C 175 engines used in 300 and 350 tractors used a 361479 R1 for gasoline. You may have something else though. If it doesn't have 1/4 inch pipe thread opening in rear of head it may be same as above head.Date code or picture of combustion chamber would help on ID.
