kocking from rear hubs
Randy Vaughn
08-31-2006 22:56:46
I have a Farmall B. I'm starting to here a loud knocking (or bumping) noise coming from the hubs of the rear tires when I'm driving the tractor. I can shake the tractor sideways slightly by pushing against the back tires. It seems like there might be some play in the axle. Dose anyone have any suggestions of what this might be?
gene bender
09-01-2006 02:42:47
 Re: kocking from rear hubs in reply to Randy Vaughn, 08-31-2006 22:56:46
Your bolts that hold the rim to the center dished section are loose i would replace with new as the area where the bolt goes thru the rim and center section is probably worn. Use good lube on the threads.
HAS
09-01-2006 03:46:04
 Re: kocking from rear hubs in reply to gene bender, 09-01-2006 02:42:47
And grade 8 bolts!
Hugh MacKay
09-01-2006 05:09:17
 Re: kocking from rear hubs in reply to HAS, 09-01-2006 03:46:04
Don: That grade 8 bolt is very important. Back when my son was about 18, I was going away for the day, he was going to work the 130 all day. I told him to put a wrench on the wheel bolts as we had them off a few days before.
I got home that evening and he told me that after his days work the wheels were loose again. I took 2 of the grade 5 bolts out. He had used a 3/4 drive with a long handle and streched the 5/8 bolts to a point they were only about 3/8 in the middle. Now, those grade 5 bolt were old and pited with rust, I had used them one day in a hurry, always intended to exchange them for grade 8. Yes, grade 8 very important especially when you have a young lad with a big wrench. I have a 6' railroad crowbar, my grand father got it when he was a young man. Through 4 generations, the 4th generation was the first to bend it. He sheared Christmas trees every summer as a teenager, that job tends to put arms and shoulders on one, much like a body builder. After that I always had fun kidding him if we were doing wrenching. I'd tell him to use a 6" handle for tightening wheels.
Hugh MacKay
09-01-2006 01:30:31
Randy: Sounds like loose wheels or wheel weights. Those can knock even when they don't look loose, wrench is the only sure way to check.
Might be loose axle. Jack the tractor under final drive, pay special attention as the weight comes off the wheel. When wheel is clear of ground then try end movement on the axle. If the axle is loose, you best not run it until fixed.
Let us know what you find, I'd check for loose wheels first.
