hay nat 2
stu in njo
09-01-2006 13:54:34
I rebilt the c60 engine about a year ago crank was sent to machine shop. Leak started a short time after it was put back to work. I'm thinking of puting a c113 in it if I can make it fit hight will be the big thing to work out.Thanks for the input Stu.
Bill Geer
09-01-2006 19:09:36
 Re: hay nat 2 in reply to stu in njo, 09-01-2006 13:54:34
Stu I did a rebuild on a c-60. And had the same prolbem. After about 8 hours the oil ran out the rear seal. I put in 3 seals and 3 seal holders. For some reason you can't buy the rite seal for the rear of a c-60.To fix this I got a seal sanded it and the retainer.put them togatherand put a bead of J-B weld aroud it.Been 2 years no leaks.
Bill
billde
09-01-2006 15:28:11
if it's the front crank seal leaking there is a sleeve available.
Nat 2
09-01-2006 14:41:06
Hmm, could be just one of those things, then... "Infant mortality" where the seal just plain didn't last long.
IaGary
09-01-2006 14:39:20
Stu
What is a hay nat 2?
Gary
IaGary
09-01-2006 14:43:26
 Re: hay nat 2 in reply to IaGary, 09-01-2006 14:39:20
Sorry I see now he is talking to nat2.
My Bad.
Nat 2
09-01-2006 14:42:39
That be me. Referring to a thread from a couple days ago.
I was afraid he was going to yell at me... Haven't stepped on any toes around here in a while, so I couldn't figure out why he'd be mad :)
