Order Farmall Cub Parts Online
cub problems
jeff cummins
09-01-2006 18:16:47
I have a cub that will not run right unless the choke is one third closed,we have tried eveything carb fuel flow vac leaks ignition no luck any ideas? thanks jeff
jeff cummins
09-02-2006 12:25:01
 Re: cub problems in reply to jeff cummins, 09-01-2006 18:16:47
We rebuilt the carb,checked fuel flow from tank, cleaned out discharge nozzle all the little holes are open, still have same problem,cant figure this one out.Also, when you put tractor in gear,it grinds until you let clutch out I am thinking throw out bearing? we greased it, that did not help.
billde
09-01-2006 20:18:27
All good advice here, but while on the subject of compressed air NEVER blow air into the fuel inlet of the carburetor! To do so may collapse the float.
Bob
09-01-2006 21:16:09
 Re: cub problems in reply to billde, 09-01-2006 20:18:27
Oh, HORSEFEATHERS...
gene (missouri)
09-01-2006 19:53:48
Plugged or partially plugged main jet. The Cub carburator is very simple. Disassemble and clean (dip). You may or may not need a kit. I would take the carb apart before I purchased a kit.
Roger46
09-01-2006 19:24:09
If you have good fuel flow to the carb, it could be several things in the carb. It could be a plugged jet or the float set wrong. May need to get a carb kit. Roger
shawn manck
09-01-2006 18:46:29
sounds like you are not getting the right amount of fuel to the carb from the tank. take the line loose from the carb and blow through it with compressed air. i had the same problem with my super a a couple of weeks ago, had a piece of rust stuck in the fuel bowl i just took a small magnet and pulled the piece out of the tank after i blew it out
MAGMAN
09-01-2006 18:33:37
Try taking the line off the carb and put compressed air to it and turn the bulb on there may be a blockage in the top of the bowl where it goes into the tank. It happened to me. JON
