Super A clutch problem?
10brooks
09-02-2006 08:53:42
My Super A has decided it won"t shift into gear. With the pedal depressed when you attempt to put it in gear there is a bad grinding sound. Shifts fine with the engine off. Any ideas on things I can look at to decide what to fix?
10brooks
09-09-2006 06:07:43
 Re: Super A clutch problem? in reply to 10brooks, 09-02-2006 08:53:42
Well, I pulled the starter, tried the brake cleaner idea..... started it in gear and rode around a while but still no luck
banjo
09-02-2006 12:22:52
I had a simular problem with a allis chalmers, one of the arms on the pressure plate was cracked.thus not getting a complete release.
old
09-02-2006 09:17:40
Cluthc disc maybe stuck to the flywheel. Pull the starter off and look in. Have some one push the pedal down and see if the preassure plate releises any. If it does then take some brake cleaner and spray into tha clutch disc and also turn the engine over some to get it cleaned. You can also start it in gear and drive it around, but make sure you have a lot of room to do that and make sure no ones in your way becuase you will not be able to stop it easy till it pops loose. Thats a common problem with tractors.
