Igniter Electronic Ignition
Goat Killer
09-02-2006 09:48:58
My goats got in with my modle H and ate the wires off my coil. I have changed it over to a 12 volt negative ground. As I can['t find the instruction sheet that came with the parts, I was wondering if one of you might know where the two wires go. Thanks
Jossette
09-02-2006 18:53:25
 Re: Igniter Electronic Ignition in reply to Goat Killer, 09-02-2006 09:48:58
third party image
model H
Bus Driver
09-02-2006 14:56:54
You'll like this very old children's song.
John T
09-02-2006 14:14:42
GK, I believe they make modules for either Pos or Neg ground so be sure n get it right or you could damage something.
John T
Bob
09-02-2006 09:53:42
Wire from ignition switch (and resistor, if used) to (+) coil terminal.
RED wire from Pertronix Ignitor to (+) post on coil, BLACK wire from Pertronix Ignitor to (-) side of coil.
Goat Killer
09-02-2006 10:24:13
 Re: Igniter Electronic Ignition in reply to Bob, 09-02-2006 09:53:42
thanks Bob
Bob
09-02-2006 12:39:27
 Re: Igniter Electronic Ignition in reply to Goat Killer, 09-02-2006 10:24:13
P. S....
Appropriate "handle"!
