Help Request
Charlie-CO
09-04-2006 06:42:33
I's working on a Farmall H and have two 3/8 by 3/4 inch cap screws with bend up retainers on them and wonder if you could tell me where they go. I tried to use them as the cam retainer bolts but couldn't fit them in there. Thanks for your help
glennster
09-05-2006 11:01:42
 Re: Help Request in reply to Charlie-CO, 09-04-2006 06:42:33
i think those bolts go inside the timing cover, they hold the front plate to the motor. i am pretty sure those go right near the governor gear.
Charlie-CO
09-05-2006 23:38:47
 Re: Help Request in reply to glennster, 09-05-2006 11:01:42
Thank you all for your help.
glennster
09-05-2006 10:54:16
i am pretty sure those bolts go on the front of the motor under the timing cover. they hold the plate to the engine block. i think they go near where the governor gear come through.
banjo
09-04-2006 10:48:26
does the oil pump bolts use them on the H's like the A,B,C's.? might go there.
Charlie-CO
09-04-2006 12:03:03
 Re: Help Request in reply to banjo, 09-04-2006 10:48:26
Those are 7/16th inch bolts. Thanks for your relly
MAGMAN
09-04-2006 08:01:01
If memory serves me right there are only a few places that use a bending tab bolt washer. the crank bearing and on the front of the motor. I think that the plate that goes over the front of the motor may have two of them in there but I do not think that the cam does I believe they are just lock washers. So that thin plate is where you need to look and see. If I had my vidio here I could tell you where but it may be self exsplanitory. JON
Charlie-CO
09-04-2006 06:48:29
I meant I"m, not I"s.
Pa. Pete
09-04-2006 09:50:39
 Re: Help Request in reply to Charlie-CO, 09-04-2006 06:48:29
The flywheel-to-crankshaft bolts have them, I saw on a video.
Charlie-CO
09-04-2006 12:09:56
 Re: Help Request in reply to Pa. Pete, 09-04-2006 09:50:39
You're correct but those are 1/2 inch bolts, I believe. Thanks.
