Farmall H Starting problem
gulch
09-04-2006 12:09:32
All of a sudden my H won't start. Battery charges and cranks the engine. I put in new points, condenser and new coil. No change.
Fuel appears to be feeding and floods the carb, dumping out by the rubber air intake.
Do I have to take the carb apart...or are there other ideas? Gas two weeks old. Has stabilizer in it. Could the stabilizer be the problem>
Michael Soldan
09-04-2006 14:41:45
 Re: Farmall H Starting problem in reply to gulch, 09-04-2006 12:09:32
Gulch, it sounds like the carb is flooding itself, the float may be stuck, tap lightly on the carb with a screwdriver, this sometimes dislodges the float and then try starting it..gasoline dripping out the air intake is a "flood " sign...Mike in Exeter Ontario
El Toro
09-04-2006 13:20:42
Check the plugs to see if they're wet. Hold one of the plug wires near the plug and see if they're getting fire while someone attempts to start the tractor with the ignition switch on.
Hal
