confused about farmall M carb adjustment
garry lee
09-05-2006 13:48:10
i have a farmall M that seems to run rich. fouls out two plugs after running for a while, maybe a couple hours depending on job, but it's black soot, plus i have a slight bit of smoke out the stack. at any rate i've been doing some searching on adjusting the carb and cant find much, is there not just the idle screw towards the top of the carb and the main screw towards the bottom, other then taking it apart, which i dont have time to do right now, i just want to get it to stop fouling plugs so often and thoght i would start with this.
thanks
RustyFarmall
09-05-2006 15:25:56
 Re: confused about farmall M carb adjustment in reply to garry lee, 09-05-2006 13:48:10
From what you are describing I would say that your carb is beyond any help you could give it by making adjustments. I would guess that the float is way out of adjustment or is leaking, the needle valve is dirty and sticking, or the main metering tube has some problems. But, before you get too carried away, you might want to clean and service the oil bath air cleaner, and also make sure that the choke plate is opening fully.
Yugrotcart
09-05-2006 15:09:31
Initial settings are: main 2 1/2 to 3 turns
idle 1 to 1/2 turns.
Yugrotcart
09-05-2006 15:10:17
 Re: confused about farmall M carb adjustment in reply to Yugrotcart, 09-05-2006 15:09:31
Should have read idle 1 to 1 1/2 turns,,,,, ,,,
magman
09-05-2006 14:22:28
Hopefully It is your carb and andys right on the money BUT I had an H a few years ago that did the same thing and it was a worn engine actually the valves were letting raw fuel through it needed a valve job super bad when she smoked it was black not blue and she did not burn oil I did not know that much about them, then and the machine shop said it was becuase the intakes were worn so bad. $150.00 late and a $100.00 valve set and no more smoke. JON
Andy Martin
09-05-2006 14:02:00
The main screw at the bottom should be screwed in until the smoking stops.
However, the idle screw is an air screw admitting air to the idle circuit. If you screw it in, you cut off all the air and richen the idle circuit. The idle circuit does not affect the fuel much under load, however.
