F400 lpg What fluid should be used in transmission
VOLfarmall
09-06-2006 03:16:41
What fluid should be used in the transmission? it does have the T/A the operators manual says 80-90, but I use Hi-trans in my SMTA.Is there a difference? Thank You
dhermesc
09-06-2006 06:29:34
 Re: F400 lpg What fluid should be used in transmis in reply to VOLfarmall, 09-06-2006 03:16:41
With a TA you should use "Hytran", IH experienced TA failures due to the heavier oil, especially in the winter. That being said you can get by using the cheaper Hytran equivelants in the rear end of a 400.
amo
09-06-2006 06:23:09
READ POST BELOW
