SMTA Problems?
dej(JED)
09-06-2006 05:44:08
FYI--I was mowing when all of a sudden the MTA starts missing and stumbling along. After pulling the choke a little, it clears up for a bit. I finally had to drop to 1st gear and with the choke pulled out completely, I limped in to the garage. Thinking I had carb trouble I checked for gasoline and found all to be well. Next I checked the manifold for problems. The plugs and wires ,ect. where all okay. At this point I tried to restart it and the battery was dead.The alternator belt had broken and the problem was caused by a very low battery. I wouldn't have though it would behave that way, but I guess you learn something everyday like they say.
Bob M
09-06-2006 06:39:37
 Re: SMTA Problems? in reply to dej(JED), 09-06-2006 05:44:08
That's a classic symptom of a battery going dead. It's also a good reason to glance at the gages every few minutes. The ammeter would have told you IMMEDIATELY when the belt broke!
(Incidentally had your alternator had been wired up with a warning light, the light would have come on the instant the belt broke. That's why for alternator conversions I recommend the warning light over the alternative series resistor or diode...)
