Order Farmall Cub Parts Online
282 cubic inch Diesel 560 vs. 706
Farmall_Phil
09-06-2006 10:08:36
I was wondering if anyone could tell me what differences if any there are between the 282 cubic inch Diesel that was used in the 706 Farmall versus the one used in the 560 Farmall. They look like the exact same engine on the outside. Were there any internal differences. Thanks in advance. Phil
SamC-VT
09-07-2006 06:54:10
 Re: 282 cubic inch Diesel 560 vs. 706 in reply to Farmall_Phil, 09-06-2006 10:08:36
Don't I also hear about larger valves in later 282's?
K.B.-826
09-06-2006 16:37:47
There were a few changes made from the time that engine came out in the 560 until it was last used in the 656, although I don't know right off the top of my head when each change occured. Somtime during the production of the 560, the injectors were changed. Later, possibly during the 706's, the wrist pins were made quite a bit bigger.
Hugh MacKay
09-06-2006 13:35:34
Phil: Pump settings and governed speed setting were the main difference. 560 was governed at 2000 rpm with 540 pto at 1800. 706 was goverend around 2400 with 540 pto at 2300. Probably those extra rpm's gave the added hp. There were a couple of changes before the days of 706 and 656, I've forgotten exactly what but think it was in the head.
Wardner
09-06-2006 18:23:54
 Re: 282 cubic inch Diesel 560 vs. 706 in reply to Hugh MacKay, 09-06-2006 13:35:34
The 660 was tuned like a 706. It ran at 2400 and developed 80 HP. It required a bigger radiator and a six bladed fan vs five for the 560.
Nat 2
09-06-2006 10:43:56
I believe the most major difference between the two engines is the setting on the injector pump.
