UHM power unit
Duner Wi
09-06-2006 10:16:13
Am looking at what I believe from #s on left side of engine an International UHM power unit ,6 cyl. gas with magneto. From pictures in the archives it looks a bit like a W-40 tractor engine. Does anybody know anything about this engine? Thanks.
Tobaccoman
09-06-2006 18:15:40
 Re: UHM power unit in reply to Duner Wi, 09-06-2006 10:16:13
Don"t sound just right for the power unit counterpart to the W-40 tractor. These units were designated PA-40 or PK-40 depending on whether they were for gasoline or kerosene. I believe you are referring to the engine number and not the chassis number and if so, the power units engine number should begin with PTM or PKE(all the gas ones begin w/ PTM and the very early kerosene ones). The chassis serial number(and model number) is found on a plate attached to the lower rear right hand side of the sheet metal. Also has a large oval air intake protruding thru the hood on the left side. It"s a rather large unit, measuring six feet long from front of radistor to end of shaft and about "chest high" to a six foot man(or woman for that matter, to be politically correct). Nonetheless, I hope this info helps you determine the identity of the power unit.
duner Wi
09-06-2006 19:23:22
 Re: UHM power unit in reply to Tobaccoman, 09-06-2006 18:15:40
Thanks for the reply, I will look again and repost in a few days.
