Rear tire size
Farmall h pulle
09-06-2006 18:33:04
What is the largest size rear tire you could get on an H or Super H? the rules say i can go onesize over stock.
jhb
09-07-2006 13:18:56
 Re: Rear tire size in reply to Farmall h puller, 09-06-2006 18:33:04
Probable were 11X38 which is now 12.4X38. One size over would be 13.6X38. That is about right in 4000 and 4500 pound classes. Any one else have 2 cents worth?
Nat 2
09-07-2006 05:52:34
With available stock rims, I would have to guess 15.5x38. If you cut the rim and widen it, 20.8x38 because that's the largest 38" rim tire I know of. If you throw away the rim and hub, and roll your own, any tire size is possible.
