How to mount hydraulic lines?
JayWalt
09-07-2006 06:05:51
Do they make mounting hardware for hydraulic hoses. I need some way to mount 1/2" hydraulic lines on appx 3 inch pipe so that abrasion doesnt ruin the hoses? TSC and the local hardware store had nothing.
JayWalt
09-07-2006 21:10:32
 Re: How to mount hydraulic lines? in reply to JayWalt, 09-07-2006 06:05:51
I was referring to keith-or. Those are protectors, from what i can tell, but not mounts. I will look into the adell clamps and see what i can find.
Thanks guys.
JayWalt
09-07-2006 20:51:54
I appreciate the info keith, but I'm on a budget of $0 for this thing and I keep going overbudget as it is (=P). I like the idea of the garden hose.
I will probably make something, dunno, wondering how they are mounted on stock loader setups.
Keith-OR
09-07-2006 22:09:30
 Re: How to mount hydraulic lines? in reply to JayWalt, 09-07-2006 20:51:54
Jay, I had no idea the cost of those things, I haven't used any myself either.
Here is how the hoses are attached to the old Deerborne loaders. It is 5 inches long, made to go around 2 1/2 pipe. Made out of 3/16 by 3/4 inch strap.HTH
third party image
Keith
KEB
09-07-2006 19:23:04
Adell clamps. They're rubber coated metal clamps, sort of like a conduit clamp but make a complete circle when closed. Do a Google search. I've also seem something similar at NAPA to use for cable clamps.
Keith
Jossette
09-07-2006 17:05:46
I used conduit straps and self tapping screws.
Keith-OR
09-07-2006 16:55:35
OK Jay, I've got answer and info for you on protectors for hydraulic lines. I decided I would just go to friends house and talk to him as it had been awhile since we got to visit, thanks for needing info gave me an excuse.
Here is the website.
Keith & Shawn
Keith-OR
09-07-2006 09:59:08
Yeppers Jay, made about 2 miles from my place. Life long friend developed, patented and produces them. Will get info and post later today. Very simple setup.
Keith & Shawn
RustyFarmall
09-07-2006 08:37:58
You can slit a garden hose lengthwise and wrap it around the hydraulic hose, and then use plastic wire ties or even wire to hold the hoses in place.
Andy Martin
09-07-2006 07:47:51
Abrasion takes a LONG time to damage a hose. If you wear through the rubber covering you have another rubber liner then stainless steel wire to rub through.
You could use large wire ties to hold the hose in place or plumber's tape (soft perforated strap).
If you can fabricate something you can bend strap in a double ended spoon or question mark shape and use two straps to clamp the pipe and hose with a bolt in the middle.
