ROPS for a B414
wkw
09-07-2006 08:26:30
Hello,
Hoping that I can take advantage of the collective wisdom on this board.
I have a B414 up here in Alberta, Canada and I would like to put a ROPS on the unit for my safety. I live in the badlands and my property is quite hilly.
Are aftermarket units available or is this something that I will have to have custom made by a welding shop?
thanks
Ken
wkw
09-07-2006 14:30:15
 Re: ROPS for a B414 in reply to wkw, 09-07-2006 08:26:30
Thank-you very much Don. I will contact them.
Ken
Big Don
09-07-2006 12:36:17
If you go to www.laurin-inc.com they list a ROPS (roll bar) for the B414. They are located in Laval Quebec. Yopur local dealer may be able to get it from Laurin for you. I would recommend you not have one made by a local welder as the mounting points and stresses need to be correct since your life may depend on it. If you add a roll bar, make sure you add a seat belt and then USE IT every time you get on the tractor. (if the tractor rolls over and you get thrown off, the roll bar might not do much for you)
Don
