Boring out an H
Farmall'47
09-07-2006 17:46:25
I"m thinking about pulling the sleeves and using 3.75 pistons. Can I get Flat top blank car pistons so I can put wrist pin in the right location so that I don"t have to stroke the crank?I don"t want to have to get different rods. Thanks. AJB
ChadS
09-07-2006 18:45:34
 Re: Boring out an H in reply to Farmall'47, 09-07-2006 17:46:25
There is a 3-11/16 bore piston out there but I cant remember who has em at the moment,,, for a low gear puller, dont need any more than that for a engine if thats what you have in mind. 2.5 inches on the compression height for the H-350,,, optimum pin diamter is .875 or less to have room to offset the bushings enough to compensate if needed. Ive seen 175 ci engines in the mid 50's in power,,,, thats with a 350 head, cam, carb and manifold. ChadS
