Farmall A pistons !!
tyler cohrs
09-07-2006 20:36:41
Hi i have a 1945 farmall a and would like to know if i could put Super A or C pistons in it. Just wondering if that's a good way to increase power. thanks
Red Dave
09-08-2006 04:43:51
 Re: Farmall A pistons !! in reply to tyler cohrs, 09-07-2006 20:36:41
Sure you can. C and Super A pistons are the same as A pistons.
I would do as gene recomends below, oversize 3-1/8 inch diameter pistons with high compression for good results.
gene bender
09-08-2006 03:38:33
There are several ways to go. you can use the same dia pistons with different domes for higher compression and also can use larger sleeves to increase the bore and then the same route with hi-dome pistons. Best way would be a FIRE POWER kit from HOWARD ENTERPRISES 3 1/8 boresleeves and the hi-dome pistons should give you 123 cu in and around 22hp when done.
