1466 Horsepower
61-4010
09-08-2006 05:00:45
Howdy. I have a 1466 with a 436 motor. Assuming all things standard, what is the horsepower for this machine? I"ve looked all over my manual and I&T book and all they provide is cubic inch info. Curious as to what the HP might be. Thanks in advance.
randy hall
09-08-2006 12:42:02
 Re: 1466 Horsepower in reply to 61-4010, 09-08-2006 05:00:45
the early 1466's were rated at 135. but when deere came out with thier 4630 at 150 hp ih raised the rpm's 200 and raised the rating to 145 hp.
MAGNUM
09-08-2006 07:54:24
1466, doesnt have a intercooler. i have mine set at 165, she has been to 230 before, but at the tractor pulls, the highest class i pull in is 200 hp.
Jonfarmer
09-08-2006 05:20:57
I've got a tractor dyno tested at my local Case IH dealership for $40, had an H tested last year. If you want to find out what your tractor is actually making for power, thats the way to go.
Farmer Ryan from WI
09-08-2006 05:13:28
At the drawbar 118 HP
PTO is 134 HP
61-4010
09-08-2006 12:29:04
 Re: 1466 Horsepower in reply to Farmer Ryan from WI, 09-08-2006 05:13:28
Ok....so the 1466 Turbo (just like from the factory) is 134 at PTO and 118 and the drawbar. Correct? Just wanting to make sure....that I"ve got my numbers straight! Thanks!
Weldon K
09-10-2006 12:39:16
 Re: 1466 Horsepower in reply to 61-4010, 09-08-2006 12:29:04
From Nebraska Tests
Early--2400 rpm engine-133.40 PTO hp 116.97 Db hp Late---2600 rpm engine-145.77 PTO hp 126.91 Db hp To determine your model look at information-serial number plate on injection pump. RPM's will be listed.
Nat 2
09-08-2006 05:32:43
It's very likely that the HP is much higher than that... With the turbo and intercooler, over 200HP at the PTO is easily obtainable with a relatively simple injector pump adjustment.
In addition to that, rumor has it that IH liked to send their tractors to Nebraska detuned a little, so when the farmers got their tractors, the horses seemed a little bigger.
That may be the rated HP, but to see what the tractor REALLY has, a dyno test is the only way to go.
