NEW hydraulic pump install?
granger
09-08-2006 10:06:05
I have on the board a lot recently concerning problems with my hydraulic pump & have determined that I am just going to replace it with a new one. The tractor is a '51' M & has live hydraulics & is NOT the M&W pump. I just wanted to see if you guys had any "tips" or "helpful hints" on taking out the old & installing the new one. I have never did this before & needed any help I can get! Thanks
arod
09-08-2006 12:15:38
 Re: NEW hydraulic pump install? in reply to granger, 09-08-2006 10:06:05
well, the cam gear does not align with the hydraulic pump gear in any particular tooth.
though, as suggested, you will save yourself re-timing the engine to the distributor if you do not turn the engine over when you are replacing the live pump.
Allan In NE
09-08-2006 11:08:48
Hi Granger,
Mark the distributor housing and the rotor as to their position. Exactly.
Do not turn the engine while you've got it apart.
Then, just replace the pump and make darned sure the distributor and rotor are lined up as before.
Allan
Gordy from Iowa
09-09-2006 02:16:20
 Re: NEW hydraulic pump install? in reply to Allan In NE, 09-08-2006 11:08:48
Is $560 a decent price for a new pump?
