alternative radiators for Farmall H ?
arod
09-08-2006 14:13:25
Farmall H
My radiator is the sorriest, bent, leaking, soldered piece of junk bar none.
know of any small automotive ones that will fit in there?
Andy Martin
09-09-2006 06:05:46
 Re: alternative radiators for Farmall H ? in reply to arod, 09-08-2006 14:13:25
I had an M with a Pontiac radiator. They even put the sleeve through the tank.
The tractor ran a lot cooler when I finally replaced it.
The Chinese radiators will fit OK but you do have to work with them. If you know that going in it is not tooo bad, just frustrating if you don't know it whenyou start. They do last.
Good used is the way to go.
Mike CA
09-08-2006 16:46:13
I would certainly trust Cowman first, but here are a couple I found on Ebay
Link
This might be one of those Chinese ones...
http://cgi.ebay.com/Brand-New-Radiator-For-IH-Farmall-H-Tractors_W0QQitemZ300023878783QQihZ020QQcategoryZ46559QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Nebraska Cowman
09-08-2006 15:28:01
I can sell you a good used one.
Email Cowman
third party image
Mike CA
09-08-2006 15:09:12
I have seen several on Ebay. I think one of them was even brand new.
kfox
09-08-2006 16:22:12
 Re: alternative radiators for Farmall H ? in reply to Mike CA, 09-08-2006 15:09:12
Don't buy a chinese radiator!!!!! !!!! Won't fit, never intended to fit. All mounting holes are 1/4 to 1/2" off. Get a used one from Cowman or somewhere. I just spent two days beating, hammering, prying & cussing to get one of the cheap chinese radiators mounted on my old H.
ken
Roger46
09-08-2006 18:36:16
 Re: alternative radiators for Farmall H ? in reply to kfox, 09-08-2006 16:22:12
I have also had trouble with even the US made replacement radiators. They almost fit, but don't really. Roger
CNKS
09-08-2006 19:42:27
 Re: alternative radiators for Farmall H ? in reply to Roger46, 09-08-2006 18:36:16
My experience also.
