Question: The Correct Police Phenomenon
David Kronwall
09-09-2006 04:17:02
I'd like to know your ideas and opinions about the "correct police." I used to work in the model railroad industry (yes, industry) and I think that world has a similar group we used to refer to as "rivet counters." These were the guys who would criticize a model box car because it wasn't exactly right, didn't have precisely the same number of bolt heads or some other fitting as the original. I assume with tractors, we're talking about the same approach, right?
If that's true, I guess I feel this way. It takes all kinds of people to make the world lively and interesting, and that's the way it should be. I can appreciate that a person who KNOWS what the factory did originally thinks a restoration should reflect that as closely as possible. In a way that makes it more accurate, legitimate, real. But I also recognize the point of view that it's your tractor and should be what you want it to be--whether the facory made it exactly that way or not.
I'm a bit in the middle.
I think a vintage Farmall should be driven, not put in a glass case and just stared at, but it should be clean and run well and be painted so it looks shiny and red. As we used to say at the ag equipment shortliner company where I worked, "It's just iron, my friend." But the iron should be well-kept and maintained and a source of pride for the owner. If a bolt or wire or headlight or seat cover is different from the original, who cares? How important is that?
The most meaningful thing to be about this world of vintage tractors is the PEOPLE you meet in it. Nice people--most of whom are glad to share their knowledge and experience and will help others, newbies like me, as much as they can. It's the tractors, especially the red tractors, those glorious machines, that bring us all together.
As others have said many times on this forum, that's my $.02 worth. I'd like to know anyone's ideas on this "correct police" phenomenon.
David
moseed
09-10-2006 08:00:25
 Re: Question: The Correct Police Phenomenon in reply to David Kronwall, 09-09-2006 04:17:02
I am happy that people keep the old times and tractors alive and that they (people/gatherers) come in every shape size and philosphical configuration. I appreciate the time and resources put into a good restoration as much as I appreciate a perfect runner in her work clothes. I like to see farmer ingenuity almost more than the perfect tractor. What did correctness mean to those families getting that tractor delivered before during or after the deppression..? the dust bowl days? I am absolutly happy as a clam that lots of folks see value in them and so be it that value is in the eye of the beholder. Many of the tractors that are being collected now were owned previously by someone else who couldn't imagine ever letting letting it go. If we think someone's treasure could look better maybe it will in 50 years and two or three owners from now.
davpal
09-09-2006 22:53:51
I think if I were putting one in a museum I would try to make it original for people to see. But for my personal use I like to make them nice and then use them for years, and about ten or fifteen years later, clean and paint them again. You can always make a tractor look new again but you also have to use em for what they are made for. Working and getting dirty. I did a ford 9n and painted it ford blue with white sheetmetal because I personally liked the combo much better than grey and I have to look at it every day! The oringinal aspect has been lost on a few things. I have 8n fenders with the ford script. I have an 8n block with thick wall sleeves. I have it converted to 12 volt which I love, good starts, bright snowplowing lights, ability to jumpstart any vehical if it needs it. I also have 15 inch front rims with 7.50-15 armstrong oversized tires that I like very well. So it is far from original but I think it looks much better than it did when it was original. I get a lot of compliments on it so it must look pretty good! later
Hugh MacKay
09-10-2006 04:21:57
 Re: Question: The Correct Police Phenomenon in reply to davpal, 09-09-2006 22:53:51
davpal: You briefly touched on tires, and a lot of folks will critize incorrect tires. Most of them don't know that even in the 1950s there were optional tires. In 1958, my dad bought a Farmall 130 with 11.2x24 rear and 5.50x16 front. One can no longer buy a 16" replacment rim for any of SA, SC, 100, 130, 200 or 230. Even CaseIH partsmen will tell you it never existed. While I've never seen 16" front rims on SA or 100, I have seen them on all the rest and factory original I might add. I had been running 15" rims on my 130 for the past 10-12 years as that was all I could find.
Last year I decided to do something about those front tires. Aftermarket guys wanted $60. per rim for blank 4.5x16 rims and they couldn't supply lugs to match that rim to the 130 wheel. I discovered that donut rims from the last rear drive full size GM cars had a 4.5x16 rim. Using a grinder I took out the centers, made up a circle band 1/2x1-1/2, spot welded it inside the rim, then, welded lugs to that band to fit my 130. The rims are black, looks nice against the red. I have 6.00x16 front tires on the tractor. I also like them much better plowing snow with my front mounted blade. With the 15", I used to push far enough, and between snow behind blade and tires over an obstical, I couldn't back away. The 16" tires did 2 things; raised the blade higher and they roll over frozen obsticals much better.
Am I correct, yes I contend I'm more correct than the folks that claim they sell a complete line of rims for tractors. By the the way, I was with my dad the day he bought that new 130. The dealer had in stock that day 4 Farmall 130s and 4 - 230s, all equipped with 5.50x16 front tires. My brother currently owns one of those 230s and it still has the factory original IH 16" front rims. You try and find a dozen guys that remember 16" rims on those tractors. Your Ford probably had the same option. I know I'm trying to find a 4.5x16 rim for my 140, parts guy has them for 8N and Jubalee, same bolt pattern, but the offset is a bit different.
Jim Becker
09-10-2006 07:52:15
 Re: Question: The Correct Police Phenomenon in reply to Hugh MacKay, 09-10-2006 04:21:57
Hugh, my reference shows a 4x16 wheel for the 140. Same wheel was available on the Farmall 240 and 340. A slightly wider (4.25) wheel was used on some 240 and 340 Utilities.
I don't know if that will help you find wheels for your 140 or not.
Hugh MacKay
09-10-2006 10:10:47
 Re: Question: The Correct Police Phenomenon in reply to Jim Becker, 09-10-2006 07:52:15
Jim: I already know a source for the 140 wheels. 4.5x16 with the right offset so 5.50 or 6.00 tires don't interfere with ty rods. Miller Tire in Ohio have them. I think I'll put 5.50 on 140. 6.00 work well on 130 for the way I'm using it, however they do look rather mean on a small tractor.
I like the flotation I'm getting from 12.4x24 on rear. When I changed my cultivator ground working tools from IH to new S tines, I needed a bit more ground clearence. I like the 12.4x24 for plowing, disking and my 6' field cultivator. They are a pain for backing a trailer or wagon, so I tend to do those jobs with SA on 9.5x24. Not much else you can do with a Woods belly mower under the tractor.
Now, I just have to find the time to drive to Ohio. Damn brokerage fees at broder would double price if they came small order by frieght. Since I want to see country, I may as well spend brokerage fees on gas.
DennyF
09-09-2006 19:55:05
Here are three of my favorite answers that I've heard given to critics:
In response to a guy's comment that a Ford Jubilee wasn't the correct shade of gray - "It's the shade of gray that I wanted it to be."
The time a guy stomped up and pounced on a buddy's 12 year-old kid, yelling at him that his JD-B should have a yellow seat and not the new black one that was on it - "We have three with yellow seats and they make me wanta puke. That's why I brought this one."
And one guy that jabbered for about 20 minutes, picking apart every detail that didn't suit him - "Do YOU own any $#%& tractors and are any of them here for US to $#$& look at?"
Other than the tractors themselves, my second favorite part of shows would be listening to how folks deal with critics.
One of my cousins owns several restored Fords and a 6 cylinder Funk that he's currently working on. The F-12 he's been working on for two years is just about finished. He told me the other day that he's got a spare pair of Ford fenders that he might put on the F-12 when it takes it to a show, just to raise a few hackles. ;O)
Thack
09-09-2006 19:46:22
At 0630 my Father in law called to see if I was ready, be there in 15 minutes he said. My wife told me to pull the bush out of the flower bed before I leave so I hoped on the Super M and got it out.
The FIL and I drove an hour to look at a 1066 and bought a 2 row cultivator for the H and 2 #8 plows for parts. On the way home we spotted a 706 gas and took a look, probably buy it. Then we went by the cemetary and dug a grave with the 300U backhoe. We unloaded our treasure, ate lunch, drank a beer then I pulled the 706D out of the way so I could pull out the 1586 and get the grain head up to his house with him following in the combine.
Then we got on the M and other 300U and did a little bush hoggin before we went to the other cemetary with the backhoe and filled in a grave.
After all that we went to the other barn grabbed a few beers and pulled up a few chairs. As we sat looking at this big thing in front of us he asked; Do we want to fix up a tractor this winter or get that picker working and mounted back on the M and do about 20 acres the old way, we got cultivators for the H now too??
Ok but remember, when the women get their winter time, all couped up, man hating fever it's your year to get skinned alive. Deal he says with a grin.
One more thing, are we ever gonna paint that yellow right rear wheel on the M silver I ask? Heck no he says, the paints still good.
Hugh MacKay
09-09-2006 18:31:57
David: I see two or three distinct groups of owners of old tractors, and I really have no problem seeing the point of view of each group. The first group are the show group, and most of these guys try to be original. Sometimes that is not always possible. I don't think the chrome and other flashy metal add a lot. There are a few items I will critize and indeed have at a show. I was at a show, guy had a wide front Farmall H with ty rods behind the axle. I could have accepted that had it been IH or Schwartz. However this wide front was fabricated at a local shop using MF 65 spindles, hubs, wheels and complete ty rod assembly. Now this guy has 75 fully restored letter series Farmall tractors. He quite often get paid for displays. I was not the only guy that critized his wide front that day. In my opinion, someone like that, enough money to restore 75 tractors, he best get it right.
By the way, at the time I did not know the id of the fabricator of that wide front. Turns out he was a guy I know very well. One day I walked in his shop. He said, "I understand you guys down in XXXXX didn't like OOOOO's wide front. It was trucked from the show to my place and I was told to get rid of that wide front. I had told him in the beginning it wouldn't wash." My point is if the guy that strains the budget to restore 2 or 3 tractors gets it 99% correct, there is no excuse for these big money guys.
The other groups I see are pullers, and I understand their agenda. Then we have the guys restoring 60s, 70s and 80s tractors for commercial use, a very good option in my opinion. Then you have young and old like myself, who keep a tractor in top mechanical condition for their own personal use. There is also another group, buy an old tractor, do bare maintainence, run until it quits, sell it and buy another. In my opinion these last groups can do any and every upgrade they deem necessary, to make the tractor suit their use.
Vacherie
09-09-2006 17:54:21
I enjoy looking at the nicely restored tractors but after looking at 20 or 30 almost perfect JD or Farmalls it is nice to see a tractor in not-so-perfect comndition especially if it is a good running F12 etc. But when I get a new-old tractor I always replace the bent nails with cotter pins. It is also nice a few Masseys, Fords, Olivers, etc.at tractor shows.
jal-SD
09-09-2006 17:34:17
I like to look at a tractor that looks like it just came from the factory, but I also find it very interesting to see the "yankee inginuity" that some previous owner used to keep his tractor working or a modification that he did to make it more efficient. I have a '54 SC Case that has its original paint, (& its not too faded, either)original readable decals & has really straight sheet metal. Previous owners obviously took good care of it. But it has been converted to a 12V alternator at some previous time. Should I change it back to its original 6V generator? Probably, BUT thats not the way it was used by previous owners, so thats the way I'm going to keep it. Its my tractor & I can do what I want with it & I can give the "correct police" something to gripe about. (My $0.02 worth. jal-SD)
Shaggy
09-09-2006 12:39:12
I am just in it for the fun and meeting new people at the show plowing matches and such. I love when people come up and start picking mine apart and I tell some of them they are just jealous that they don"t have one like mine. And when they say yes I do I ask where is it and they usually walk away.
lee
09-09-2006 12:05:37
I don't think there was ever an old time farmer who ever worried about keeping his tractor orginal in lieu of just keeping it running so he could do the work he needed done. I my mind, as long as it's running it's good enough for me and just the fact it's running may keep it out of the scrap yard for a while at least.
Tom Windsor
09-09-2006 10:57:21
I guess I am the nut in the crowd. When I get an old piece of junk, I research it as much as I can and talk to everyone who knows anything, then I set out to restore it to factory origional. Yes, sometimes at shows, when I see decals and other stuff stuck in the wrong place...I might (will) mention it! Most of the time I listen...and only speak when it is obvious that I know more than the other fellow--which is not often.
TW
Gauger
09-09-2006 09:54:38
My 2 cents: There may be correct police out there but that is all they are. I have yet to meet one that actually "does". They just like to criticize. Everyone has their own thing. I spend thousands of hours on my tractors and I'll get these guys that stop by at the show who don't speak. They slowly circle, hands folded behind their backs, staring, inspecting, more circling and then after five minutes of this I get "what's with the stainless hardware?" rather than "nice tractor". At that point I use a response that I stole from a good tractor buddy, "It's MY tractor"
Now at the risk of ruffling a few feathers; I bleed red but my I've been to many shows and the green guys definitely seem to put more into their work than the Farmall boys in both quality and originality. Fire away.
CNKS
09-09-2006 09:14:47
I am not a professional, and do the best I can. I do not try to restore every dot head bolt, I sometimes order the repros, most likely I just use one that fits. I don't know how to duplicate the factory paint, so I take pride in a good acrylic urethane job, it looks better than factory, factory can't be duplicated anyway, as the "correct" color does not exist anymore. It's only a hobby, I spend a lot of time on it, and always have decisions to make as to whether I want to repair, replace, or use as is a "serviceable" part. I really do not care how other people fix up their tractors, all I care about is how I did mine. -- BUT, I enjoy looking at all of them, and am not going to criticize someone elses tractor, no matter what I think about it.
HENRY E NC
09-09-2006 08:07:31
Many of us restore old iron to bring back fond memories of our youth. Some of my best memoried are those of sitting in the tractor seat listeing to the smooth roar of the engine and singing at the top of my lungs as I turned beatiful earth and prepared it for planting. Memories of a well spent youth. I remember all that when I am working on my 51 M and 41 A and taking them to a show opens doors to many new friends. (Not a correct police retoration but close). I even point out the many old bolts witha dot to people who are in awe of the older pieces of iron.
Wardner
09-09-2006 07:59:00
I say "to each his own"
I prefer looking at tractors as they would appear coming off the assembly line. Yes, that would include electroplated galvanized rims and sloppy IH paint jobs. For the most part, I would not like to see signs of wear on seats or pedals.
While it might be interesting to look at Bonnie and Clyde's bullet ridden '35 (?) Ford sedan, I would spend more time looking at a similar car that was properly restored; particularly if I owned one.
Dave in MN
09-09-2006 07:50:56
I'm one of the pullers who "wreck" old iron for sensless competition... I pull red tractors and my wife for some reason likes my clothes to be clean (at least starting out in the morning of the pull that way). A couple of years ago I grabbed a clean shirt without really noticing just what it was and when I got to the pull, I couldn't beleive the people bent out of shape because I had a JD shirt on while I pulled a red tractor. I now TRY to have at least one different brand of clothing on per pull. I't kind of fun to watch some "riviet counters" go off!
Hugh MacKay
09-09-2006 17:39:10
 Re: Question: The Correct Police Phenomenon in reply to Dave in MN , 09-09-2006 07:50:56
Dave: I took much the same kind of heat here last summer. Most of the folks I'm acquainted with here at YT know me as a Farmall guy. Well, Bob M put that photo of me and my good better half on the YT farmall page. My wife got lots of compliments, then they poked fun at my legs, general looks and my Oliver hat. I still get jabs from time to time about the hat. Now, the hat was bought for one purpose. A neighbor has Deere tractors and I was told it was green hats only in their shop. I complied. I discovered the mesh on the Oliver hat, keeps sun's rays off my bauld head much better than my Farmall, IH, JD, MM, MH and MF hats do. So until the rest make a good sun hat, I will be wearing my Oliver hat.
The interesting part on the Farmall designation for me, is when I farmed, yes I had a lot of Farmall tractors, but I also had a Cockshutt, a John Deere and two Case. My tillage and planting equipment were IH, haying and forage was all NH and my combine was MF, and now I feel most comfortable with the Farmall guys here at YT.
jayw
09-09-2006 06:50:29
To me the best thing about restoring a old Tractor is the satisfaction of making her work again. Just remember Its your tractor and you do as you Please, Ive been picked at for things I have done but most od the Time it was from guys who bought there Tractor already restored,They know what they are suppose to look like but they havent restored there own. I do have a friend that is a excellant Mech. and he just has to put everything back to original, But you have to remember it his Tractor.His money. JUST Remember have Fun and meet real neat people cause for every jerk you meet in this game there is a 1000 cool folks
Ken L.
09-09-2006 05:46:38
I have a few tractors of different colors that I have restored and will be restoring. I do everything myself except for machining. I try to keep them as close to original as possible but I do make a liitle change once in a while. What gets me is when some jerk does his best to find something and pick it apart. I had my 27 D J.D. at a show last year and some guy came along and started ranting about the fact that I painted the fan yellow. After about ten minutes, I asked him if he ever owned or restored a tractor. Of course, his answer was no. I told him to move on. I heard that about an hour later a guy with a M Farmall knocked him on his butt. Whoever that guy is, Thank you.
Andy Martin
09-09-2006 05:06:46
Take woodworking.
There are those who will not use power tools or modern glue, but they design their own furniture. There are even those who want to cut their trees and mill the lumber by hand. Then there are those who don't care about what tools are used, but build traditional furniture from a bygone era which is hard for experts to identify as reproductions.
Blacksmithing:
Some insist on only using coal forges to do their work, and hand punch or hand drill every hole. No power involved. They may or may not use traditional designs. Then there are those who use propane forges, air hammers, arc welding, etc. but only make traditional designs.
Cars:
Street rods, museum antiques, drivers.
Antique Tractors:
I find it extremely amusing that people will go far out to have all round dot bolt heads, then chrome plate parts of the tractor. They worry about what is "correct" until it comes to what they like. Thinge like 6v system with clear coat finish.
I have sympathy for those who want to show a "factory fresh" tractor, I'm just not one of them. Those who truly want factory fresh can really go all out with braided wire, etc. In a properly judged show a shiney pain job is as bad as cut-offs. (I don't mind cutoffs: they are traditional, just not factory).
I have no sympathy for pullers, who destroy old iron in a useless competetion.
Then there is the vast in-between. They want an old tractor to show or use. They need to know how to repair it. They would like it to look original. Unfortunately some people are in desperate need of reinforcement so they will try to do what others think is right. In this day and age it is senseless to run an expensive 6v system when 12v is available.
Bottom line, this is an open forum and all can contribute. We can all respect one another while not agreeing with their view. You will definitely not change another person's ideas and view. I despise cutting the hood to put on an alternator but it is no worse than the guy who put a flip up hood on his. Crying over mis-matched casting numbers is about as bad.
After all, it is just old iron.
alaskan
09-09-2006 05:24:50
 Re: Question: The Correct Police Phenomenon in reply to Andy Martin, 09-09-2006 05:06:46
I'm with the crowd on the very last line.
Tractors are tools and they've always been tools.
I can't imagine what my Dad would have said about putting chrome parts on a tractor just for looks. I don't recall him ever buying anything just on the farm just for fun. If we had one of anything, it worked for a living.
Criticize my tractor? May as well criticize my chainsaw. It won't mean anything to me.
Andy Martin
09-09-2006 05:44:08
 Re: Question: The Correct Police Phenomenon in reply to alaskan, 09-09-2006 05:24:50
Careful, you'll offend a chainsaw collector.
MJin the UK
09-09-2006 05:06:00
Intresting comments Dave. Here in the UK we get over the top restorations with parts of the tractor painted black, silver etc or even chrome plated. Tmake matters worse the tractor gets praised in the tractor magazines then other restorers think they should do it to their own tractors. I have my uncles unrestored 1956 Fordson Major tractor with the original blue radiator grilles but because the magazene editor praises the restored tractors with the grilles painted orange the younger generation ask me why my grilles are blue. MJ
Andy Martin
09-09-2006 05:09:49
 Re: Question: The Correct Police Phenomenon in reply to MJin the UK, 09-09-2006 05:06:00
Have you seen the current cover of Red Power?
A C with crhome grill! It would not have looked good even in 1958 but it is a cover shot.
pgo12
09-13-2006 17:52:51
 Re: Question: The Correct Police Phenomenon in reply to Andy Martin, 09-09-2006 05:09:49
i think it looks sweet. pg
brainerd dave
09-09-2006 05:02:01
I've never asked for an opinion on how my tractor should look and I don't give one to anyone else. Shiny and red in a museum or covered in manure and muck in the field, both have their place and I'll stop and look at either one with the same interest. Yes, the people you meet in this forum are very nice and helpful, but the people you meet in every field of interest are just as nice and helpful. I don't find that tractor enthusiasts have a monopoly on that aspect.
richard in nz
09-09-2006 04:47:05
I agree, any way it is very near impossible to get factory fresh and lets face it those same correct police would scorn a factory fresh restoration of a tractor any way, look at factory photos of Ferguson TE tractors coming of the line with overspray all over the tyres, when M-F 165 trators were new we had to turn the sedimentor bowls on the pre-delivery check, why?, because they were painted over grey. Rivet counters, correct police, call them what you will, also have another thing in common, they never turn up at a show or event with their own restoration!
edf iowa
09-09-2006 07:33:08
 Re: Question: The Correct Police Phenomenon in reply to richard in nz, 09-09-2006 04:47:05
I worked at a Cadillac dealer decades ago. I was working on a Fleetwood when a salesman that had been there 20 years wandered over, looked under the hood, and asked me if it was a 6 cylinder or an 8. The guy new his paint colors and his interior fabrics, but didn't know squat about cars. The folks that have never farmed and own a tractor that sits in their garage in the suburbs and only use it for shows and parades are kind of like that.
If they get enjoyment out of that, more power to them. They can just keep their advise to themselves.
pgo12
09-09-2006 14:37:16
 Re: Question: The Correct Police Phenomenon in reply to edf iowa, 09-09-2006 07:33:08
i like em all. dont matter. but dont feel bad, i took one of my old ih tractors to a show and a guy and his buddy where inspecting my tractor very closely. he told me and my son that ih never made the tractor. my son and i couldnt do anything but laugh. pg
pgo12
09-10-2006 01:03:48
 Re: Question: The Correct Police Phenomenon in reply to pgo12, 09-09-2006 14:37:16
a fairway 12. pg
forklift
09-09-2006 18:27:25
 Re: Question: hey PGO12 in reply to pgo12, 09-09-2006 14:37:16
hey pgo12 , what tractor was that ?
kfox
09-09-2006 19:10:27
 Re: Question: hey PGO12 in reply to forklift, 09-09-2006 18:27:25
Every hobby has its share of correct police. I used to do Civil War re-inacting. I got too old for that hobby (couldn't keep up with the kids)
It seemed like every other guy was a member of the correct police force. My Brother and I went to Gettysburg to be in the Movie "Gettysburg", and there we ran into the Mother Of All Correct Police. These two Pretend Officers walked by our camp, and one stopped to look at my coffie pot. Then he started telling the other guy " Look at that. That just makes me sick. Some people don't know anything about History or the Civil War. Where did you guys get that coffie pot - Wall Mart? I picked the coffie pot up and dumped it out, and then I rubbed the smoke off of the bottom in the grass. Read this mister smart guy, I said. I don't remember the brand name now, but the Patent date was 1851. It was nickle plated copper with a black wooden handle. I had found it in a local antique store, and it was just like new. The two wise guys walked away, and I heard one telling the other " I didn't know they had coffie pots like that, back then."
Sorry I went off on a tangent, but that hobby had the worse case of correct police I've ever seen.
ken
kfox
09-09-2006 19:15:29
 The Spelling Police got me in reply to kfox, 09-09-2006 19:10:27
Ha, miss spelled coffee all the way through my last post and didn't see the error until I posted it. sigh
ken
Hendrik
09-11-2006 00:39:50
 Re: The Spelling Police got me in reply to kfox, 09-09-2006 19:15:29
Sort of liked your spelling. The Dutch word for coffee is koffie ;-)
