Brands of pistons
Charles McNelly
09-09-2006 20:45:21
After pulling the head om my B and seeing the 1"+ recess in the head, I figured I need to use pop up pistons to get the compression up. The problem is TISCO brand has only a 1/4" dome on top of there step head piston. I would like to see at least a 1/2" dome. Just who all makes kits for these tractors?
Thanks, Charles
randy hall
09-10-2006 09:16:48
 Re: Brands of pistons in reply to Charles McNelly III, 09-09-2006 20:45:21
i am a distributor for howard enterprizes and their ' red power' line of parts. the pistons with the real high domes or steps are no longer available. they were for use at high altitudes or changing a low compression engine to get more power on gas or propane. howards offer american made firecrater piston sets.
Charles McNelly III
09-10-2006 15:09:26
 Re: Brands of pistons in reply to randy hall, 09-10-2006 09:16:48
Thanks for the info Randy. By chance could you tell me the height of the dome on the piston you carry? 3 1/8" pistons.
Charles
gene bender
09-10-2006 08:43:22
Look at the ones from HOWARD ENTERPRISES
forklift
09-10-2006 05:56:45
MagMan carries A&I From what I saw in there catoloug they did not tell a size but maybe you could call them or mag and have him find out. I know the shape and size of the ones I bought pretty much compare to fire crators. Not step head .
El Toro
09-10-2006 04:15:08
Clevite has sleeve & piston kits for farm tractors. Hal
