Deck bearings ih 3260 deck lowboy
Gregg in ohio
09-10-2006 18:44:59
Any decent replacment bearings for this deck? Part numbers..looking at alternatives before calling ih dealer..thanks gregg
K-Mo
09-11-2006 04:17:48
 Re: Deck bearings ih 3260 deck lowboy in reply to Gregg in ohio, 09-10-2006 18:44:59
Gregg,
The bearings shouldn't be hard to find. Most any bearing or automotive store should have them. The trick is to adjust them. They are tapered bearings and are set with a spacer installed between the upper and lower bearing. When you buy from CaseIH, you buy a set of bearings with a precision made spacer. If you buy off-the-self bearings you may need to resize your old spacer or make a new one through trial and error fitting.
K-Mo
El Toro
09-11-2006 03:29:02
Try bearingsdirect.com/products. The phone number is 818-956-0651 or email them at sales@bearingsdirect.com Hal
