gm diesel in farmall
wegman
09-11-2006 14:21:42
this is a dumb qwestion does anyone know if you could put an oliver gm diesel in a farmall m/ta?
davpal
09-11-2006 22:08:07
 Re: gm diesel in farmall in reply to wegman, 09-11-2006 14:21:42
There was one at the oakley tractor show this year in michigan. It was done very nicely. The motor fit in there like it was made for the tractor. They had a spacer plate on the bellhousing but everything looked great and fit under the stock sheetmetal perfectly. Later.
DCW
09-11-2006 17:27:23
You can put whatever you choose into an M,but the fact of the matter is that the transmission was designed for about 45HP or so,not 90.IH themselves tried to up the horsepower without beefing up the transmission-with disasterous results.Later on,of course.
Wardner
09-11-2006 18:19:24
 Re: gm diesel in farmall in reply to DCW, 09-11-2006 17:27:23
Detroit Diesel has never released a 90 hp 2-71. That is not to say one could not be modified by turning up the governor and fitting larger injectors. Engine longevity would suffer.
I don't know what the specification was for the kit installed 2-71. I would have to assume it was around 50 hp. That would be equivalent to one third of a contemporary industrial 6-71 at 150 hp. And one should bear in mind that the rated power was produced at a higher rpm than the M engine. 1400 (M) vs 1800 (2-71). Consequently, the torque was probably less than a M.
One should also bear in mind that the kit was not "shadetree" engineered. The package was sold thru Detroit Diesel dealerships and had to have been warranteed.
Paul G. in Mn
09-11-2006 15:55:20
A while back a guy had a 1939 M with a 2-71 on ebay. It was done very nice and looked very clean.
Wardner
09-11-2006 14:52:35
The GM diesel, more commonly known as Detroit Diesel, had a Farmall M installation kit mfgd by DD or aftermarket. These tractors show up at Red Power Round-ups fairly regularly. Only the 2-71 was adapted.
I can sell you a 12V71 if you got a hankering to build something different.
Andy Martin
09-11-2006 15:00:58
 Re: gm diesel in farmall in reply to Wardner, 09-11-2006 14:52:35
A 12v71 or a 16v71 would make a real mean F-12.
I'd hate to garbage up an M-TA however.
