Purchased an M today
Patrick in Illi
09-11-2006 17:02:52
My grandpa and I purchased a 1945 Farmall M today. New rubber and wheels, starts and runs great. Purchase price was 1300.00 and for 300.00 more, a 3-point hitch. Drove it 30+ miles home; not a single problem. And it used very little gas!!! It has a 9 speed transmission that works smoothly too. I thought it was a great deal that I just had to share. Patrick
darn
09-12-2006 09:32:45
 Re: Purchased an M today in reply to Patrick in Illinois, 09-11-2006 17:02:52
this also makes the PTO run twuce as fast
Patrick in Illinois
09-11-2006 20:05:57
Not sure how it installs, but from what I can tell, it gives you a high and low gear, similar to a TA, but you need to clutch to shift it. Grandpa remembers it being offered in the 50's. Patrick
BDM
09-11-2006 19:30:53
I've read about this 9 speed. What is it exactly and how does it install?
Brian
Andy Martin
09-12-2006 05:32:02
 Re: Purchased an M today in reply to BDM, 09-11-2006 19:30:53
It is a two speed gear setup that goes from the input shaft to the counter shaft so you have two ranges for reverse and 1-4. Since you have two ranges for each of the four work gears plus road gear it gives you nine speeds.
BDM
09-12-2006 05:59:10
 Re: Purchased an M today in reply to Andy Martin, 09-12-2006 05:32:02
Thanks. I take it that the ratios are reduced? How does it mount?
BDM
09-12-2006 07:39:15
 Re: Purchased an M today in reply to BDM, 09-12-2006 05:59:10
Thank you gentleman
Andy Martin
09-12-2006 07:22:44
It replaces gears within the transmission.
kfox
09-12-2006 06:35:33
The low range is a little lower than the factory gears, and high range is a little higher. My H will start out with a load in 4-H, and is almost as fast as the factory 5th gear. 5th gear is not effected by the 2 speed addition. ken
Yugrotcart
09-11-2006 17:34:49
Shoulds like you got a good deal. I am sure that you and Grandpa will have a lot of fun with it, enjoy!!!!! !!!
55 50
09-11-2006 18:16:38
 Re: Purchased an M today in reply to Yugrotcart, 09-11-2006 17:34:49
just noticed your "name" is tractorguy spelled backwards!
Paul Shuler
09-11-2006 18:44:23
 Re: Purchased an M today in reply to 55 50, 09-11-2006 18:16:38
55 50, You are way sharper than me. I have wondered for a long time what kind of name that was. Thought he might have a yogurt store. Man I feel dumb.
Harley
09-12-2006 09:57:25
 Re: Purchased an M today in reply to Paul Shuler, 09-11-2006 18:44:23
Paul, don"t feel too bad, I"ve tried several different ways of pronouncing it and never did come up with a viable answer. Makes all the sense in the world now. DUH. Harley
Andy Martin
09-12-2006 11:51:07
 Re: Purchased an M today in reply to Harley, 09-12-2006 09:57:25
And I thought it had something to do with an aristocrat's Yugo.
There you go!
