3 Farmall Tractors Need help on Model Numbers
Greg755
09-12-2006 08:48:01
I have 4 FarmAll tractors going up for auction. Could someone Please look at the pictures on my website and email me what Model and year they are?
Thanks
Greg
www.AuctionNy.com go to the auction for Sat Sept 23 then click on View photo Gallery.
you can email me at
greatamericanah@rochester.rr.com
Thank You
7 cs farm
09-14-2006 20:07:54
 Re: 3 Farmall Tractors Need help on Model Numbers in reply to Greg755, 09-12-2006 08:48:01
i have a farm all that i dont know the year of it was bilt in 46 so sas the last owner it has all the gauges on the dash and has a wood floor board
also it has hand controled brakes it looks like an h but the rims have flat spokes in stead of the mag like rim on the h so if u know pleases help me id the tractor.
gene bender
09-12-2006 19:30:55
The BN has part of the BN-238 cult lift assy still there. Dont have any idea what the front stuff was used for. The H is the one with only half the cult on maybe they just did one row.
Mike CA
09-12-2006 16:48:50
third party image
The serial number tag should be on the left side of the clutch housing. For an H which is your bigger tractor, the number should start with "FBH", followed by the actual serial number, possibly followed by one or more other codes.
Andy Martin
09-12-2006 08:54:44
Big one is an H, small one is a B (maybe a BN).
greg755
09-12-2006 08:58:24
 Re: 3 Farmall Tractors Need help on Model Numbers in reply to Andy Martin, 09-12-2006 08:54:44
Thanks, Are you talking about the two Older ones? Do you know what years they were made?
thank you G.
CNKS
09-12-2006 09:18:19
 Re: 3 Farmall Tractors Need help on Model Numbers in reply to greg755, 09-12-2006 08:58:24
If you will post the serial numbers, someone can look them up for you, or you can find them under "Serial Numbers" to your left under "Research and Info" on this site. H was built 1939-very early 1953, B from 1939-1948, Cubs from 1947-1979, the red one is likely mid-50's the yellow International later.
