Order Farmall Cub Parts Online
Cub valve job
cubber
09-12-2006 10:25:06
Anyone know of a good tool for removing the valve springs/keepers? I've got one for 'regular' sized engines but it's too big for the small spaces of a cub. I've gone the screwdriver route before, too slow. Any recommendations? Thanks!
john *.?-!.* cub owner
09-13-2006 06:36:32
 Re: Cub valve job in reply to cubber, 09-12-2006 10:25:06
I use a brigs and stratton type compressor, but I have turned one set of jaws over and rather than squeezing the spring with it, I rest one jaw on the casting below and open the compressor to push the spring up. When reinstalling the keepers put a little dab of grease on the inside. They will stick to the valve stem while you release the spring.
cubber
09-13-2006 17:49:50
 Re: Cub valve job in reply to john *.?-!.* cub owner, 09-13-2006 06:36:32
Thanks, john! I've heard that before and it 'do' work.
Thanks!
09-12-2006 18:17:58
Thanks to Andy and gene, I'll check out the sears one first, it's closer. Appreciate the help!
gene (missouri)
09-12-2006 11:50:23
Sears has an adjustable valve spring compressor for just under $20.00.
It will work on the Cub. You will need to use a block of wood on the top of the block because the height adjustment isn't great enough for the Cub.
The Sears valve spring commpressor works well on other small engines.
Andy Martin
09-12-2006 10:38:50
Check out the spring compressers for Briggs and Stratton.
