'43 Farmall H needs Overhauled
Matt in PA
09-12-2006 17:09:58
Hello All,
I need to get my ’43 H overhauled. It was my grandfather’s, which he bought in ’47. I know it has never had any motor work done to it and it still has the original clutch, which is weak. The compression in the all cylinders is down around 95 psi and she fouls plugs and burns oil real bad. What would be a cost estimate to have her put back in sound mechanical shape? I was considering using the Case IH dealer Hoobers in Lancaster PA. What are your thoughts? Thanks, Matt
MTC
03-07-2009 12:52:19
 Re: F12 front steel wheel in reply to oldiron29, 03-07-2009 08:43:46
third party image
another view from the front.thanks
gtx1967jewison
03-07-2009 12:29:40
 Re: piston clean up in reply to Janicholson, 03-06-2009 10:46:38
WRONG! read the guy above- no steel wool. but also NO sandpaper. its 2009! ever hear of 3M scotchbrite? even comes in 4 different "grits"! i would recommend the red color.
P K Ouellet
03-07-2009 10:59:38
 140 hydraulic system in reply to Janicholson, 03-06-2009 10:46:38
adlm
03-07-2009 09:43:53
 Re: Engine Overhaul in reply to P and R Pete, 03-07-2009 07:12:20
Man, you just rained all over my parade. It"s ok though, I still think I"m up to the challenge. At least, I think I will be by the time I start. I can be a bit impulsive, but i can also keep my cool. It sounds like I"m going to do just fine, with a little help from my friends. I do have a couple of people who know engines really well that I could turn to in a bind.
Mike Schwartz
03-07-2009 09:05:25
 Re: SMTA rear end in reply to Harold hubbard, 03-07-2009 04:44:03
I hope that will be the case. I will jack the tractor up and see if I can hear anything. I just redid the brakes and they were not oily, but I did not remove the backing plates. Will the bull pinion or axle feel loose at all or do the housings support them to well to tell if there is a bad bearing? I will dig into it today and report back, thanks, MIke S.
Matt in PA
09-14-2006 14:35:57
 Re: '43 Farmall H needs Overhauled in reply to Matt in PA, 09-12-2006 17:09:58
Thanks for all the infot! Most likely I will be doing some reading up and try and tackle it this winter. Thanks agin, Matt
old
09-12-2006 19:30:16
You can pretty well figure at around $60-100 per hour for labor and 10-20 hours labor. Then you have parts which could be any where from $500 just for an overhaul or up to around $1000 for a rebuild. Overhual being new rings, rod and mani bearings, and a vlave job. That wouldn't include things like haveing the crank turned or other thing that it may need. If you do the work your self you can do it for around $1000 give or take a little depending on what all would need to be done by a machine shop. These numbers are only ball park and they maybe differant for your area
tom Windsor
09-12-2006 19:15:12
 Compression 95 PSI?? in reply to Matt in PA, 09-12-2006 17:09:58
What is the usual compression on these low compression engines????? I thought it would be 80 or below?
Glenn FitzGerald
09-12-2006 18:01:23
If you plan on hiring that work out, you better have pretty deep pockets. When you're done you'll probably have 5x or more into the little tractor than what it would bring at an auction. In refurbishing old tractors a person generally needs to do their own work. Even then it's not hard to end up with 2-3x into a project what it is actually worth. However, when repairing "grandpa's" tractor, all the rules change. One cannot attach a dollar value to such a project. Enjoy the process, and all the folks you meet/deal with along the way. That's the most fun part. WARNING: tractor collecting and refurbishing/restoring is addicting.
Glenn F.
El Toro
09-12-2006 17:56:59
Why don't you rebuild the engine yourself? You can get sleeve and piston kits from this forum.
The have an overbore sleeve kit that has stepped head pistons for $ 348.00. Click on Engine kits
at the top left of your monitor's screen.
Call Hoobers and see what they would charge. They have 4 dealerships in the area. Two in PA and 2 in DE. Don't you have a friend that likes to do engine work? You could pull the engine, but before you do, you need to take pictures and make good notes and sketches where everything is attached. This is so you know where and how goes back together. Hal
