More on painting
Todd L
09-12-2006 19:33:24
I'm also painting a Super M. The main parts of the tractor are painted. I'm still assembling some small parts. I did not paint all bolts, nuts and some hydraulic fittings when rest of tractor was painted. I was planning on just brushing some of the small pieces. Most of the tractor was painted 10 days ago. Am I going to run into trouble?
ET
09-13-2006 06:45:48
 Re: More on painting in reply to Todd L, 09-12-2006 19:33:24
I use a piece of cardboard and shove the bolts through it and spin the nuts and washer on the back side. I can hang it up and prime and paint the hardware with the rest of the tractor. The paint has the same hardener and shine as the rest of the tractor.
CNKS
09-13-2006 06:12:11
Touchup gun is ok, but you will have to mask it all off or you will see overspray. An airbrush might be safer, I have never used one, thus can't comment. You can do a fairly decent job with a brush, but it won't be perfect. As to the fittings, I put true hydraulic fittings on my Super H, rather than the pipe fittings. They are plated and I did not paint them. Looks ok to me. Hand brushing may or may not be noticeable on the regular pipe fittings.
El Toro
09-13-2006 04:13:55
I would use a Touchup HVLP gun. Hal
