stepped head pistons or flat tops
Brad in WI
09-13-2006 02:38:31
I have a '41 H that needs new pistons and sleeves (it is apart now). The head casting number is 8043-DC. The serial number is 58122. Can I use the stepped head piston rebuild kit from this site or not. Also it says that the valve length is 5 5/16" long but mine are about 5 3/8" long. The motor had flat top pistons in it when I purchased the tractor but it was also in a box. I had the head just cleaned up nothing extra taken off. Just want to do it right the first time. thanks
forklift
09-13-2006 04:52:35
 Re: stepped head pistons or flat tops in reply to Brad in WI, 09-13-2006 02:38:31
iT SOUNDS LIKE YOU HAVE THE 5-15/32" VALVES. They generaly run a little more than the other.
