tachometer on the hundred series
biggerred
09-13-2006 09:31:53
Can I swap the tach off of a 300 utility with one(thats dead) on my 400, or is there a gear or calibration issue between the 2?
Farmall450man
09-13-2006 09:51:47
 Re: tachometer on the hundred series in reply to biggerred, 09-13-2006 09:31:53
The tack will fit and show rpm, but the speeds listed will be wrong. You may be able to take it apart and switch the speed scale from the 400 tach out with the 300 tach.
