h carb settings
tim coltman
09-13-2006 13:50:15
just wondering what was a good start to set the carb float and main jet at. thanks tim
RustyFarmall
09-13-2006 14:04:59
 Re: h carb settings in reply to tim coltman, 09-13-2006 13:50:15
No such thing as a good place to start, the float settings are exact. Float level is 1 27/32" Float drop is 2 1/8". The main metering tube is static, it is not adjustable. If you are talking about the high speed idle, or load adjusting screw, it is turned in lighty until it seats, and then turned 3 full turns out. This is an initial setting, it may need to be turned out a bit more if the warmed up engine stumbles under a load.
tim coltman
09-13-2006 18:33:29
 Re: h carb settings in reply to RustyFarmall, 09-13-2006 14:04:59
thanks just needed a place to start tim
