H hood??
massey 44
09-14-2006 16:18:02
I have a 1943 H that I am rebuilding and the hood has (approximately 3/16 in dia) holes drilled or punched evenly across the front and rear edge of the hood. What was the purpose of these and were there any factory hoods with these?? There is one on ebay with these holes on one end!!
old
09-14-2006 18:16:51
 Re: H hood?? in reply to massey 44, 09-14-2006 16:18:02
If you find you need a hood I have 2 of them. One has all the latches missing but the other one has all of them
HENRY E NC
09-14-2006 17:54:51
I patched my M hood several holes by taking the metal bare and fiberglassing a small round patch under each hole and then turning it over and used chopped glass with resin to fill the holes. Could also be done by weld tacking a small peice of metal inside and filling the holes with a brazing stick and grinding smooth in each case
Nebraska Cowman
09-14-2006 16:48:15
I have seen holes along the sides that were to fasten on canvas winter breaks. But no, there weren"t any holes there from the factory.
lgood1950@hotmail.com
09-14-2006 16:52:10
 Re: H hood?? in reply to Nebraska Cowman, 09-14-2006 16:48:15
Didnt think so,,,these are across the ends,,,,, ,,,to bad is a really straight hood otherwise, guess will have to invest in a different hood!! Thank You
Wild Bill
09-15-2006 07:53:30
 Re: H hood?? in reply to lgood1950@hotmail.com, 09-14-2006 16:52:10
Hit each hole with a mig welder, grind smooth.
Nebraska Cowman
09-14-2006 17:11:42
you should be able to fill the holes. Maybe with lead?
