AC delco altenator
515ryanh
09-15-2006 17:54:58
I have a ac delco altenator that the case is getting hot while charging. Its on a deisel engine while running I'll shut the key off and it seems to cool down then I'll turn the key back on it gets hot again. It has a external regulator. it seems to be charging ok but I havn't tested it could be overcharging but it dosn't seem to be cooking the batteries? anyone have any ideas. thanks
Brownie 45
09-16-2006 04:23:10
 Re: AC delco altenator in reply to 515ryanh, 09-15-2006 17:54:58
Are all wires & connections , including the 4 prong plugin to the regulator clean & free of corrosion? The regulator has to be able to "read" the batt. voltage to shut down the output from the alternator.
Bob
09-16-2006 00:18:38
By any chance, did a blem forget to install the cooling fan along with the pulley?
A buildup of debris, restricting cooling air flow, makes them heat up pretty quick, too.
Also, a shorted diode(s) or winding can cause heating, even while it's still charging. (In other words, before ALL the smoke leaks out.)
By they way, working alternators DO normally run pretty warm.
Hermit
09-15-2006 18:10:50
Have you checked that some bugs haven't built a nest in the alternator blocking the cooling air?
