Buying a TD-6
Dave H (MI)
09-15-2006 20:00:57
Can anyone tell me what to look for or rather look out for? Going to check it out tomorrow afternoon. I know it starts well and switches to diesel fine and keeps good oil pressure. My understanding is that it loses some power when it gets warmed up. Help is appreciated.
noel from nm
09-16-2006 11:55:18
 Re: Buying a TD-6 in reply to Dave H (MI), 09-15-2006 20:00:57
the td-6 is the same moter as the MD,WD or the UD-6 stationary moter. And you can acually put a stationary moter in a tractor.After you get it started and warmed up look for bubbles in the radiator. They had a bad problen cracking heads. You need to cool the tractor down after working it hard before shut down.
old
09-15-2006 21:18:56
See my post in the other forum where you asked for info
Dave H (MI)
09-16-2006 09:26:03
 Re: Buying a TD-6 in reply to old, 09-15-2006 21:18:56
Not a lot of info from either post, Rich. I guess there isn't a lot of crawler traffic on this forum. Been told to in the past to shop out the RP forums on this subject. I think I can handle it on my own. Still, you think someone here would have a comment on the diesel engine and power loss. Same engine as the MD, I think?
old
09-16-2006 09:43:49
 Re: Buying a TD-6 in reply to Dave H (MI), 09-16-2006 09:26:03
I think its like the MD also but not sure. I know it starts the same way. Problem area in them is warped valves and cracked heads. Power loss can be a good number if things. Any thing from bad fuel bad injectors to even a weak injector pump. Any of them can be a costly fix also. As I said I have an owners manual for one if you ever need info from the manual
Dave H (MI)
09-16-2006 19:11:40
 Re: Buying a TD-6 in reply to old, 09-16-2006 09:43:49
Thanks guys...I own it now so let's hope it is something cheap! I think there is a set of books with it but won't know for a couple of days.
