15/30 22/36 mccormick deering
Scott Roble
09-15-2006 20:56:40
I recently purchased a tractor at auction, that was supposed to be a 22/36. The serial number tag was missing, so I can't verify it was 22/36, instead of a 15/30. How do I tell the differance between the two? I know the engine bore is not the same between the two, but what on the chassis, will tell them apart?
russ hamm
09-16-2006 05:21:26
 Re: 15/30 22/36 mccormick deering in reply to Scott Roble, 09-15-2006 20:56:40
scott, hemiorange is right on the belts. you can check the serial number on the engine blockfor the year. it should be the same as the serial number unless the block has been changed which is unlikely on most. is yours complete, hood manifold and all original? on steel? i've had a number of those over the years and i really like 'em. kind of heavy to haul but i could usually get 'em cheap back then.
hemiorange
09-15-2006 21:21:18
A 15-30 has a flat fan belt and no water pump. A 22-36 has a vee belt with a water pump.
