Super C sickle
Curious
09-16-2006 02:54:38
Bought a super c with a sickle bar mower that came with the tractor new.Mounts to axle clamps and lifts with a rod to the touch control.7 ft cutter bar.I would like to fix it ,can someone tell me the model with no picture?
Cedric
09-18-2006 03:05:03
 Re: Super C sickle in reply to Curious, 09-16-2006 02:54:38
Your mower is either a C-21 or C-21-M. The C-21-M is a later version of the C-21. It had a stronger drawbar and an improved method of mounting it to the axle housings. I have the Owner"s Manuals for both these mowers which I can email to you if they are of any help.
Sid.
Jim Becker
09-16-2006 05:13:55
If it is fully mounted with no tail wheel, it isn't a 27V. If it has a single coil spring across the back, it is probably C-21. If there are 2 springs, it could be a 24.
Brownie 45
09-16-2006 04:14:37
27 V is the model no. Operates with a C width belt? We had one which my Grandfather got new in 1953 or 1952 - can't remember which. Good mower, but a lot of weight on the back axle. We broke a rear axle housing on the right side one time, so try not to go over rough & tough ground too fast.
RAW in IA
09-16-2006 03:18:17
Can't help with model # but dad had one like it. The C is great mower tractor, handy to maneuveer in the corners and tight places.Just wish it had another gear between third and high.
