1086 oil pressure gauge
Jim Johnson
09-16-2006 23:20:31
Oil pressure gauge has all but quit working and can't seem to find the problem. Any help would be appreciated. Has digital dash. Also the fuel gauge flops around. Actually the only gauge on that side that works right is the temperature gauge. Thanks
JJK
09-17-2006 06:22:39
 Re: 1086 oil pressure gauge in reply to Jim Johnson, 09-16-2006 23:20:31
As for your fuel guage its more than likely the sending units that are acting up. If you have or have access to an ohm meter, remove the sender from the tank, hook up the meter and move the float up and down. The meter should read steady but if it jumps around like it does the guage then thats the sender you replace. The top tank is easy to check but you probobly have a saddle tank also so make sure the fuel level is low enough before removing that sender.
IaGary
09-17-2006 04:42:54
Jim
On the oil gauge most problems occur at the wire connections at the sending unit on the side of the motor.
Try cleaning all the wire connections for all the gauges and see what happens.
This usually fixes the gauges on mine.
Gary
