Hand lift for an A?
GTW
09-17-2006 06:56:02
Have a Farmall hand lift that came with an A, now sold, wasn't attached of course. It has two levers side by side. I haven't found a pic of one attached that looks like this one. Can't find any numbers, but then most pieces are steel and not cast. Any ideas or pics would be most appreciated!
gene bender
09-17-2006 07:39:12
 Re: Hand lift for an A? in reply to GTW, 09-17-2006 06:56:02
Those levers were for a cultivator. What other info do you need?
GTW
09-17-2006 14:44:21
 Re: Hand lift for an A? in reply to gene bender, 09-17-2006 07:39:12
Thanks, gene! I am still assuming that it fits an "A".
gene bender
09-17-2006 18:53:39
 Re: Hand lift for an A? in reply to GTW, 09-17-2006 14:44:21
The B had the same set-up but the arms were longer. The B also had two levers that each lever lifted seperate. The one you think for an A had the right lever as a master and the left one just balanced the cult so when the right lever moved it moved both left and right cults together. B and BN had similar set-ups. Now these lever set-ups were different than exhaust lift-all.
