STEERING on an H
Norm Glasr
09-17-2006 11:48:03
Is there any adjustment for the steering gear on a 1946 "H"??
Mise has over 1/4 turn slop.
Norm
TomH in PA
09-17-2006 12:32:15
 Re: STEERING on an H in reply to Norm Glasr, 09-17-2006 11:48:03
You can reduce the slop somewhat by tightening a pair of castle nuts on the shaft inside the steering box. Open it up (and clean out the grease if it's full). You should be able the see how to adjust it. And make sure the big plug in front of the box is tight against the steering shaft, it takes the end thrust.
norm glaser
09-17-2006 18:42:02
 Re: STEERING on an H in reply to TomH in PA, 09-17-2006 12:32:15
Thanks, I'll try it.
20 mile ride was miserable.
paulie2
09-17-2006 12:04:30
 No Adjustment Re: STEERING on an H in reply to Norm Glasr, 09-17-2006 11:48:03
No Adjustment but here are the problems
1, Gears worn
2. Bearings worn
3 Keyway worn alowing the gears to move
4 support bushing worn.
These are the common problems and EVERY H I have had had some or all of these problems some more than others.
